herrmann_daniel
Aug 20, 2015Aspirant
SRX5308 Load balancing with protocol binding problem
I have 3 Internet connections in load balancing mode. All outgoing traffic to a specific IP adress (mail hub) must go through specific WAN port where I have a dedicated IP address. If any other WAN p...
DaneA
Aug 31, 2015NETGEAR Employee Retired
Hi herrmann_daniel,
Based from you have previously stated, do you have any inbound or outbound firewall rules configured on your SRX5308?
DaneA
Netgear Community Team
herrmann_daniel
Aug 31, 2015Aspirant
Hi, there are no outbound rules but some inbound: 1 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN1 NONE Never 2 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN2 NONE Never 3 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN3 NONE Never 4 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN1 NONE Never 5 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN2 NONE Never 6 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN3 NONE Never 7 HTTPS ALLOW always 192.168.70.1 Any NONE WAN1 NONE Never 8 HTTPS ALLOW always 192.168.70.1 Any NONE WAN2 NONE Never 9 HTTPS ALLOW always 192.168.70.1 Any NONE WAN3 NONE Never Below you can see part of the log from the mail hub. WAN3 of the SRX5308 has the IP 177.249.113.112 which is allowed on the mail hub. WAN1 has the IP 187.209.254.49 and is not allowed on the mail hub. Protocol binding should ensure that mail only goes through WAN3. 2015-08-31 11:24:32 ...rtinez@aesmexico.com ...rrmann@tamsys.com.mx PEDIDO 3000_651 TA... Sent 177.249.113.112 2015-08-31 11:29:01 ...abanne@aesmexico.com ...apia@giaguila.com.mx TRANSMITTAL FIRMAD... Sent 177.249.113.112 2015-08-31 11:30:04 ...rtinez@aesmexico.com ...atzin@geotest.com.mx RV: COTIZACION DE ... Sent 177.249.113.112 2015-08-31 11:34:57 ...acheco@aesmexico.com j.blancm@hotmail.com RV: Pago proyecto Sent 177.249.113.112 2015-08-31 11:39:30 ...acheco@aesmexico.com ...lupetam5@hotmail.com Rejected 187.209.254.49 2015-08-31 11:39:30 ...rtinez@aesmexico.com ...tamira@lister.com.mx Rejected 187.209.254.49 2015-08-31 11:40:54 ...acheco@aesmexico.com ...rrmann@tamsys.com.mx Rejected 187.209.254.49 2015-08-31 11:47:09 ...acheco@aesmexico.com ...lupetam5@hotmail.com RV: RELACION DE ... Sent 177.249.113.112 2015-08-31 11:48:38 ...nzalez@aesmexico.com ...no@redcomtampico.net Estudio de comunic... Sent 177.249.113.112 I allready tried with some variaton on the protocol binding rule like: - any service from local IP 192.168.70.1 that goes to 216.55.99.127 uses WAN3 - SMTP 587 from local IP 192.168.70.1 that goes to 216.55.99.127 uses WAN3 - any service from local IP 192.168.70.1 that goes to any internet address uses WAN3 But there are always some mail that go through WAN1 and are rejected therfore by the mail hub. Regards, Daniel
- DaneASep 01, 2015NETGEAR Employee Retired
Hi herrmann_daniel,
It seems that the logs looks normal. But I think it would be best for you to contact Netgear Support and have a case number logged regarding your concern as well as have the logs be further analyzed. Netgear Support is open 24/7 even on holidays and weekends.
http://support.netgear.com/general/contact/
DaneA
Hi herrmann_daniel,
DaneA
