dreamscape
Dec 09, 2016Aspirant
VPN client lite serial number
Hi, I have lost the serial number for my Netgear VPN client lite v5.1. I have been unable to locate it within the software's about dialogue box or Windows registry. The about baox says registered...
- Dec 11, 2016
Hi dreamscape,
Welcome to the community! :)
I believe you are referring to the VPN Lite license key, am I right? If ever I'm right, kindly open an online case with NETGEAR Support. State your concern and don't forget the e-mail address you have used when you have registered the VPN Lite license key before to your computer. A NETGEAR support expert will be responding to your query.
DaneA
NETGEAR Community Team
DaneA
Dec 19, 2016NETGEAR Employee Retired
I just want to follow-up on this again. I believe NETGEAR Support has already helped you get your VPN Lite license key. Were you able to register it?
DaneA
dreamscape
Dec 19, 2016Aspirant
I have received the serial number, but did not have the time to restage my computer. I was able to complete that today. I installed the VPN client with no prblems. Thanks.
- DaneADec 20, 2016NETGEAR Employee Retired
You're welcome! :) I am glad you have received the VPN Lite license key (serial number) and installed the VPN client just fine on your PC.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Happy Holidays,
DaneA
