njem
Jan 18, 2017Aspirant
VPN iPad ios10 to SRX5308
Before I beat my head against trying to get this VPN going and wonder why it won't work am I wasting my time? I find this article http://kb.netgear.com/25836/How-to-Setup-VPN-with-NETGEAR-Firewall-...
ChenX
Jan 19, 2017NETGEAR Expert
Hi njem
You should select the type to IPSec
Here is my config on IOS:
Type: IPSec
Description:Any
Server: SRX5308-WAN IP
Account: username (the user you added on the SRX5308)
Password: userpassword (the user's password you added on the SRX5308)
Use Certificate:OFF
Secret:the Pre-shared key on the SRX5308
PROXY: OFF
Regards
njem
Jan 23, 2017Aspirant
ChenX,
Thanks. Part way there. I think the way you set up the router end is different. On the ipad I made an IPSEC VPN connection (it offered IKE but I see yours is IPSEC).
It's offers these settings:
Server: outside IP of the office
(since I'm trying this from inside the office I've also tried using the LAN IP of the router)
Account: JoeUser
Password: (the password for the User, JoeUser on the router)
Use Certificate: off
GroupName: blank. I've also tried geardomain
Secret: (The preshared key made with the router VPN settings. I made this the same as the JoeUser password just to remove one variable.)
When the ipad tries to connect it says "VPN Connection: The VPN server did not respond."
On the router I made a user JoeUser of type "IPSEC VPN user". It says it's going to make them in user group "geardomain" but when I get back to the list of users it shows the Group column and Authentication Domain column as blank.
I made a VPN connection setup in the router using the VPN Wizard and chosing type "client". I suspect this did not create the right setup for this kind of conneciton. For one thing when I view VPN Status it doesn't even list it. What steps did you use to create the router side of the VPN?
Thanks.
- ChenXJan 23, 2017NETGEAR Expert
Hi njem
Do not add a vpn connection setup by the VPN Wizard for the iphone.
1.First, create a mode config profile. Go to VPN > Mode Config > Add.
2. Then, create the IKE Policy manually. Go to VPN > IPSec VPN > IKE Policy > Add.
3. Once done, create an IPSEC user. Go to Users > Users > then Add.
- njemJan 26, 2017Aspirant
ChenX,
Almost there. I followed your steps and on the IOS side it said VPN Connected. On the Netgear side it listed it in the status page but said IPSEC SA Not Established. That may have been because I was trying it from inside the LAN. The exec will be trying it from home. We'll see what happens then.
