RJ248842
Apr 26, 2020Aspirant
Recommended router and VPN
New to Netgear. Is there a plan to launch a rack-mounted router, and if so, what are the expected release date and if known, key specs? In the meantime, what (a) rack-mounted router and (b) VPN a...
DaneA
Apr 27, 2020NETGEAR Employee Retired
In the meantime, what (a) rack-mounted router and (b) VPN are recommended for use in a small business with very simple networking requirements
Kindly check the NETGEAR Insight Instant VPN Router which is the BR500 and it is currently available in the market. You can install it in a standard 19-inch (48.26-centimeter) network equipment rack. Also, you can use any off-the-shelf 100 mm VESA standard mount to secure the router to a wall, a pole, or another surface.
With the BR500, you can configure Site-to-Site VPN using the NETGEAR Insight VPN up to 3 BR500. Also, you can configure Client-to-Site VPN using the NETGEAR Insight VPN wherein up to 10 VPN Client users can remotely connect to the BR500.
For more information about the specifications of the BR500, kindly access its data sheet here. Check also the BR500 webinar here.
Check the links below on how to configure VPN using the NETGEAR Insight Instant VPN:
How to Set Up Remote VPN with NETGEAR Insight Instant VPN?
How to Set Up Site-to-Site VPN Using NETGEAR Insight Instant VPN?
To know more about NETGEAR Insight, kindly access the links below:
What can I do with NETGEAR Insight?
DaneA
NETGEAR Community Team
