DwayneT1
Apr 11, 2021Follower
Reinstall VPN client software
Another one... VPN client will not activate. Have attempted to lodge a few support tickets and they are just closed. Can anyone help with re-activating the client software?
- Apr 12, 2021
I got an update that your VPN license key has been reset. You may now install it to your PC/laptop.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Apr 11, 2021NETGEAR Employee Retired
Welcome to the community! :)
I have just read your private message. I have already replied to it.
DaneA
- DaneAApr 12, 2021NETGEAR Employee Retired
DaneA
- Jul 15, 2018Retired_Member
