Augello's avatar
Augello
Tutor
Aug 26, 2019
Remote IP Subnet is same as LAN IP Subnet traffic won't route
Local Office LAN IP Subnet is 192.168.1.0 Remote Home LAN IP Subnet is 192.168.1.0 VPN Client connects but nothing routes.  I beleive this is because both LANs are on the same subnet.  Is there any...
  • DaneA's avatar
    Aug 27, 2019
    Augello,
    The only solution here is to change the LAN IP Subnet to a different IP address range.  It is either you change the IP address range of the Local Office LAN IP Subnet or Remote Home LAN IP Subnet
    DaneA
    NETGEAR Community Team
ProSupport for Business
