Altos
Sep 15, 2017Aspirant
Replace FVS336Gv2 with FVS318Gv2
We are replacing our FVS336Gv2 with a FVS318Gv2. Any chance we can just export the config from the old 336 and import it to the 318? Thanks -- John
- Sep 17, 2017
Hi Altos,
It is not recommended to restore the config file from the FVS336Gv2 to the FVS318Gv2 or vice versa because both VPN Firewalls have different hardware and might cause problems.
DaneA
NETGEAR Community Team
DaneA
Sep 17, 2017NETGEAR Employee Retired
Hi Altos,
DaneA
DaneA
Sep 20, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
