Zafar
Jun 21, 2016Follower
Restore configurations failed- "CONFIGURATION FILE CRC FAILED"error
Hi Guys, I'm trying to restore the setting on my router but getting CRC failed error. I upgraded the router to 4.3.3-6 which didn't accept the setting- checksum error. Then I had to downgrade...
vlad_tepelea
Oct 22, 2016Aspirant
Hi,
There is no point to do what you say, as the .cfg file was generated on the this very device running the latest firmware. This is the third time I am telling you this.
Any useful method suggested, beside manually reconfiguring? If not, please do not answer.
Vlad
Vlad
