ChristISM's avatar
ChristISM
Configure switch in "ring"
Hi,
I would like to know if there is any special configure to configure Netgear switch in "ring", I mean 1x SFP cable from Switch 1 -> Switch 2 -> Switch 3 -> Switch 4 -> then one to Switch 1.
Thanks!
  • JohnRo's avatar
    JohnRo
    Nov 25, 2015
    Hello ChristISM,
    The  GS728TPS' are the only ones that are stackable. I'm thinking you can stack the 3 GS728TPS' and cascade the other 3 switches to them. If you will connect the switches by using thier SFP ports, I am afraid it might cause a loop.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ChristISM,
    Welcome to the community!
    What are the model numbers of these switches that you want to run on a ring topology?  If the switches are stackable, you can just use stacking instead (see definition).
    I look forward to your response.
    Thanks,
    • ChristISM's avatar
      ChristISM
      Hi! and thanks :)
      sorry for delay, it's crazy out here :D
      We have :
      • 3x GS728TPS
      • 2x GS724Tv3
      • 1x GS724Tv4
      Are they all able to be stack? Instead, I assume I can use the stack fiber cable between each switch in ring topology but is there any modification I need to do?
      • JohnRo's avatar
        JohnRo
        Hello ChristISM,
        Thanks,
ProSupport for Business
