ChristISM
Nov 23, 2015Aspirant
Configure switch in "ring"
Hi, I would like to know if there is any special configure to configure Netgear switch in "ring", I mean 1x SFP cable from Switch 1 -> Switch 2 -> Switch 3 -> Switch 4 -> then one to Switch 1. ...
- Nov 25, 2015
Hello ChristISM,
The GS728TPS' are the only ones that are stackable. I'm thinking you can stack the 3 GS728TPS' and cascade the other 3 switches to them. If you will connect the switches by using thier SFP ports, I am afraid it might cause a loop.
Thanks,
ChristISM
Nov 25, 2015Aspirant
Hi! and thanks :)
sorry for delay, it's crazy out here :D
We have :
- 3x GS728TPS
- 2x GS724Tv3
- 1x GS724Tv4
Are they all able to be stack? Instead, I assume I can use the stack fiber cable between each switch in ring topology but is there any modification I need to do?
JohnRo
Nov 25, 2015NETGEAR Employee Retired
Hello ChristISM,
Thanks,
- ChristISMNov 26, 2015Aspirant
Thanks for the info, I will leave it like this without any ring, until we change switch.
