Olddog-58
Nov 13, 2016Aspirant
Router Not Performing as advertised
I have a couple FVS114s and FVS214G. I have had complaints that they do not perform as advetised. The Wan connection is supposed to be 100Mbps, none of the WAN ports will communicate over 15Mbps. ...
Olddog-58
Nov 15, 2016Aspirant
The Data sheet on the old routers say they run at 100Mbps Full Duplex but they don't. How can we be sure this is not the issue with new routers. NetGear should offer a free return on the equipment ( Netgear will pay to have a shipping service pick up the router and refund all cost associated with the router). E-O-L has no bearing on this issue. It has been a problem with the routers from purchase but was all ways blamed on some thing else. I replaced the router for the customer with an other router. We, your resellers have to stand behind your products but you don't
DaneA
Nov 16, 2016NETGEAR Employee Retired
Hi Olddog-58,
The 10/100BASE-T is the capability of the ethernet port (WAN port) itself and this is different to LAN-to-WAN throughput. Since both the FVS114 and FVS124G has a LAN-to-WAN throughput of 11.5Mbps, it cannot go any faster than 11.5Mbps data transfer to and from the internet.
DaneA
NETGEAR Community Team
