RAXuser's avatar
RAXuser
Guide
Feb 22, 2024
RAX120 v RAXe500 performance
I have a RAX120 that is limiting my speed to about 940MB down.....   both my modem (arris s33) and my ISP support 1.2GB.      If I upgrade to a RAXe500 will I be able to utilize the full (or close to) 1.2GB?    Any other recommendations to increase my speed?     Thank you!
  • RAXuser wrote:
    1. To be connected to the S33's multigig port  - Completed
    2. to be connected to the RAX120's multigig port from the S33 - Do I change the below setting to 5G Ethernet port or the Wan Aggregation?
    Thank you again for your help!
    If you've connected it to the 5g ethernet port, you'll change it to that port.
    Then check the wan port statistics to ensure its connected at multigig speeds
  • plemans's avatar
    so you're a little stuck. Both the the RAX120 and the RAXE have multigig input. But not a 2nd multigig port for output. So the router might be getting multigig but its challenging to get it out to devices.
    Both have lan port aggregation that can get you multigig speeds but not many devices support it.
    You're (more than likely) still getting multigig from the S33. An easy test would be to run a speedtest on the hardwired device and a wireless device at the same time. It should hit faster than the 1 gig speed. You can also use the built in speedtest in the nighthawk app to see the faster speeds.
    Do you really need to make the large investment to hit multigig? Thats debatable as most sites won't saturate even gigabit. Because if they did for everyone, their server/ISP costs would be astronomical. Usually the only time you max out a gigabit line is during speedtests. Even streaming 4k only takes 25-40mbps.
    So unless you're moving truly massive downloads, its not going to impact your usage much.
    But it does feel better during testing.
    • RAXuser's avatar
      RAXuser
      Guide
      Thanks you for all the great info, very very helpful.
        One question related to your comment:  "You can also use the built in speedtest in the nighthawk app to see the faster speeds."
      When I run the Nighthawk app speed test I am seeing the 940 speed consistently.   Are you saying the I should see closer to the 1.2GB?
