jpowers
Jan 10, 2013Aspirant
routes: how to
if my isp has given me three blocks to use. i already have the primary block setup using classical routing so my computers on the lan-side can use that. if i have these two additional blocks to use ...
jmizoguchi
Jan 10, 2013Virtuoso
you need to use inbound rules and specify the WAN IP instead if you want those pc to to use gateway on router. Means you need to use NAT.
