StanAccy
Nov 06, 2013Aspirant
Routing between VLANs
SRX5308, firmware: 3.0.8-12 (later firmwares dont route UDP correctly, which breaks incoming SIP) I have two subnets 192.168.1.0/24 and 192.168.2.0/24 setup as two VLANs. We have an external DNS r...
Daedalus01
Nov 07, 2013Aspirant
When you say From the .1.0/24, are you trying to hit the other VLAN of .2.0/24 from internal? There is an Option on that router for Inter-VLAN Routing, but there is a bug evidently ( Check the VPN Section) that will cause it to stop working. I'd report it to Netgear. The more reports they get of it, the faster (hopefully) they will fix it.
