StanAccy
Nov 06, 2013Aspirant
Routing between VLANs
SRX5308, firmware: 3.0.8-12 (later firmwares dont route UDP correctly, which breaks incoming SIP) I have two subnets 192.168.1.0/24 and 192.168.2.0/24 setup as two VLANs. We have an external DNS r...
StanAccy
Nov 07, 2013Aspirant
Im done . Ive given up on Netgear firewalls. I just installed pfsense on a spare SFF Dell box, and its running great with faster throughput by about ~20mbps (speedtest.net checked).
All required ports forwarded, vlan and inter vlan routing working as expected, SIP etc. Basically what you would expect a router/NAT/firewall to do.
I'd rather have a single small 1U box like the SRX5308 in the rack doing this work, but a router that doesn't route reliably/properly isn't a router.
