LuisMaria's avatar
LuisMaria
Site to Site SRX5308 y Zyxel USG50
Hi.
I have done the Site to Site configuration of a NETGEAR with a ZYXEL and do not connect.
I have reviewed the configuration and I have updated the firewall and in principle everything is fine, but they do not connect.
Has anyone made that configuration?
If NETGEAR with ZYXEL is not compatible, what other brand can I test ?, thank you.
Spoiler
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi LuisMaria,
    Welcome to the community! :)
    I'm not sure if you have already came across with the article below.  However, kindly use the article below as reference guide on how to configure box-to-box IPSec VPN:
    Configuring a Box to Box VPN on ProSAFE/ProSECURE routers using the VPN Wizard
    Make sure that the WAN IP address registered on the SRX5308 and Zyxel USG50 are Public IP addresses.  Also, be reminded that the LAN subnet on the SRX5308 should different on the LAN subnet of the Zyxel USG50.  For example, if the LAN subnet on the SRX5308 is 192.168.1.x, then the LAN subnet of the  Zyxel USG50 should be different like 10.10.10.x or 192.168.9.x.
    DaneA
    NETGEAR Community Team
    • DaneA's avatar
      DaneA
      LuisMaria,
      I just want to follow-up on this.  We’d greatly appreciate hearing feedback.
      DaneA
      • LuisMaria's avatar
        LuisMaria
        I have done everything from the documents and configurations that NETGEAR has supplied to me and nothing at all (what I do not know if the connection problem is NETGEAR or ZYXEL
        If you can guide me in things that I can try, I will do it agusto
ProSupport for Business
