kbnetrix
Sep 02, 2016Aspirant
SNMP polling issue FVS336GV2
Hi all, Working on setting up snmp polling from a server on the LAN polling the LAN address assigned to the firewall with no luck. Few things I've noticed, I did a packet capture from the snm...
- Sep 06, 2016
Hi kbnetrix,
I'm not sure if this will help. Can you try to update the firmware from v3.1.1-08 to v4.3.3-6 and check if it would help. You may download firmware v4.3.3-6 here. Be reminded that its best to perform a factory reset after upgrading the firmware to have a fresh start using the latest version of the firmware.
DaneA
NETGEAR Community Team
DaneA
Sep 04, 2016NETGEAR Employee Retired
Hi kbnetrix,
Welcome to the community! :)
On the web-GUI of the FVS336Gv2, go to Security > Firewall > Attack Checks. Under the LAN Security Checks portion, is there a check mark on the box that says "Disable Ping Reply on LAN Ports"? If yes, kindly uncheck it then click Apply. Observe if this resolves your concern.
DaneA
kbnetrix
Sep 06, 2016Aspirant
DaneA, thanks for the response, however neither of the LAN security options are checked.
