kbnetrix
Sep 02, 2016Aspirant
SNMP polling issue FVS336GV2
Hi all, Working on setting up snmp polling from a server on the LAN polling the LAN address assigned to the firewall with no luck. Few things I've noticed, I did a packet capture from the snm...
- Sep 06, 2016
Hi kbnetrix,
I'm not sure if this will help. Can you try to update the firmware from v3.1.1-08 to v4.3.3-6 and check if it would help. You may download firmware v4.3.3-6 here. Be reminded that its best to perform a factory reset after upgrading the firmware to have a fresh start using the latest version of the firmware.
DaneA
NETGEAR Community Team
kbnetrix
Sep 06, 2016Aspirant
DaneA, thanks for the response, however neither of the LAN security options are checked.
DaneA
Sep 06, 2016NETGEAR Employee Retired
Hi kbnetrix,
What is the current firmware version of the FVS336Gv2?
DaneA
- kbnetrixSep 06, 2016Aspirant
Running - 3.1.1-08.
h
- DaneASep 06, 2016NETGEAR Employee Retired
Hi kbnetrix,
DaneA
- DaneASep 11, 2016NETGEAR Employee Retired
Hi kbnetrix,
Were you able to update the firmware to v4.3.3-6 then perform a factory reset on the FVS336Gv2? If yes, does same problem occur?
DaneA
- kbnetrixSep 12, 2016Aspirant
Have not tried new firmware, we are looking into other firewall options due to a few other reasons. If we do deciede to try the upgrade I will post results.
