kbnetrix
Sep 02, 2016Aspirant
SNMP polling issue FVS336GV2
Hi all, Working on setting up snmp polling from a server on the LAN polling the LAN address assigned to the firewall with no luck. Few things I've noticed, I did a packet capture from the snm...
- Sep 06, 2016
Hi kbnetrix,
I'm not sure if this will help. Can you try to update the firmware from v3.1.1-08 to v4.3.3-6 and check if it would help. You may download firmware v4.3.3-6 here. Be reminded that its best to perform a factory reset after upgrading the firmware to have a fresh start using the latest version of the firmware.
DaneA
NETGEAR Community Team
