Cody784's avatar
Cody784
Speed capped at 9.0mbps instead of full 25mnps
I have my router for less security. the repeter is connected to it. with prosafe FVS318v3 behind it for a nat 3 network for security l. the firewall is not reaching 25 mbps like the others. its capped...
  • DaneA's avatar
    Jul 28, 2019
    Cody784,
    Welcome to the community! :)
    The LAN-to-WAN (or WAN-to-LAN) Throughput of the FVS318v3 is only 11.5Mbps.  As reference, kindly check the FVS318v3 Data Sheet here
    If your subscription with your ISP (Internet Service Provider) is 25 Mbps, you will need a firewall router that has a WAN-to-LAN Throughput that is higher than 25Mbps.  You may want to check the BR500 that has a LAN-to-WAN Throughput of 924Mbps.  For more information about the BR500, kindly check its data sheet here.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
