R-Kasten's avatar
R-Kasten
RAX20 LAN ports are capped at 100mbs
Hello, my router (info pasted below) does not reliably give me full speed on the LAN ports specifically.  I have 900+mb/s to the modem, and if I plug the ethernet cable (cat6) directly into the modem I get my full plan download speed of 500mb/s.  If I then route the ethernet cable from modem > router, and plug my computer into the router I'll get 500mb/s once, and then 100mb/s afterwards.  If I power cycle the router, I'll get 500mb/s again but then it reverts to 100mb/s.  I've tried all 4 ports and the behavior is the same.
Hardware VersionRAX20
Firmware VersionV1.0.11.112_2.0.77
GUI Language VersionV1.0.11.112_2.1.46.1
Operation ModeRouter
CPU LoadCPU1: 5.00%  CPU2: 4.44%
CPU3: 4.27%  CPU4: 1.67%
Memory Usage(Used/Total)333MB/497MB
Flash Usage(Used/Total)110.43MB/256.00MB
System Uptime0 days 19:14:39
