dproxximo's avatar
dproxximo
SRX 5308 - Protocol binding does not work
I have two WANs up and running and selected NAT and Load balancing with weighted LB. I defined a protocol binding for FTP for WAN2 but it routes through WAN1?
The default outbound policy is "block always" and i only have one policy that allows all trafic and NAT IP is set to AUTO. Why is it not working? The only way to get outgoing traffic for specific service to specific WAN port is to define an outbound policy for each and define NAT IP accordingly, for example WAN2. If I understand correct the protocol binding should work without any outbound policies?
Firmware: 4.3.3-6
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi dproxximo,
    Welcome to the community! :)
    The outbound policy is needed to be defined for the protocol binding to work.
    DaneA
    NETGEAR Community Team
  • Do you mean NAT IP = AUTO is enough or do I need to define one outbound policy for each service (but what good is protocol binding in that case if I control everything with policies)?
    • DaneA's avatar
      DaneA
      Hi dproxximo,
      Kindly try to remove the protocol binding that is configured then just define an outbound policy in the firewall rules and observe.  Let us check if the outbound policy will just work without configuring protocol binding on the SRX5308.
      DaneA
      • dproxximo's avatar
        dproxximo
        I can confirm that protocol binding is useless or not working. I have now disabled them.
        Outbound policies works and is easy to define. I just have one outbound policy for ALL services that is defined to WAN1 and I only need to define the services I want for WAN2 and put them before the other policy. If that matches then it ignores the policies below and routes to WAN2 as it should.
        Thank you!
ProSupport for Business
