juerg
Aug 15, 2015Aspirant
SRX 5308 Firmware upgrade gone bad
After rebboot, the system doesn't work anymore. The test light is on an the console prompts: srx5308 bootloader: Does anyone knows the commands for the bootloader? How can I switch to the secondar...
- Aug 23, 2015
Hi
Yes the problem was solved by a new system. I got a replacement for free by Netgear. They told me it is the only way to solve this problem.
Juerg
