PopinatorWV
Sep 15, 2015Aspirant
SRX 5308 "https://(my router ip address)/scgi-bin/blocked.htm" when trying to view site
I am trying to access a website that as training videos on it. I have tried using a different web browser with the same results, when I look at the code after it's run I notice this line at the end "SRX 5308 "https://(my routers internal IP address)/scgi-bin/blocked.htm" I have used the instructions provided by the website, disable popup blocker, install java, install Adobe Flash player, I continue to get this message. What does this mean and what is the solution?????
1 Reply
- JohnRoNETGEAR Employee Retired
Hello PopinatorWV,
Welcome to the community!
It appears that you may have Content Filtering enabled, this will block websites that have keywords which belongs to the keyword blocking table. Please see image below for reference:
If content filtering is enabled, you may just need to remove the keyword refering to the site or add the site as a trusted domain.
I hope this one helps.
Thanks,
