JamesN33
Aug 31, 2018Aspirant
SRX 5308 Site-to-Site VPN not fully working
Hi all,
New to the SRX5308 and Site-to-Site VPN. I have used the wizard and believe that I have a successful tunnel between two SRX5308. I have done nothing other than run the wizard. I can...
DaneA
Sep 03, 2018NETGEAR Employee Retired
Hi JamesN33,
Welcome to the community! :)
Make sure that the LAN IP Address range of the SRX5308 on Site A is different from the LAN IP Address range of the SRX5308 on Site B. For example, if the LAN IP Address range of the SRX5308 on Site A is 192.168.1.x then the LAN IP Address range of the SRX5308 on Site B should be 192.168.3.x (where x is a number from 1-254).
Kindly answer the questions below:
a. On the web-GUI of the SRX5308 on Site A, go to Monitoring > Diagnostics. Then, check the box that says "Ping through a VPN tunnel?" and select the corresponding Gateway. Enter the LAN IP Address of the SRX5308 on Site B and click the Ping button. Are you able to get replies?
b. On the web-GUI of the SRX5308 on Site A, go to Monitoring > Diagnostics. Then, check the box that says "Ping through a VPN tunnel?" and select the corresponding Gateway. Enter the LAN IP Address of a PC connected to the SRX5308 on Site B and click the Ping button. Are you able to get replies?
c. On the web-GUI of the SRX5308 on Site B, go to Monitoring > Diagnostics. Then, check the box that says "Ping through a VPN tunnel?" and select the corresponding Gateway. Enter the LAN IP Address of the SRX5308 on Site A and click the Ping button. Are you able to get replies?
d. On the web-GUI of the SRX5308 on Site B, go to Monitoring > Diagnostics. Then, check the box that says "Ping through a VPN tunnel?" and select the corresponding Gateway. Enter the LAN IP Address of a PC connected to the SRX5308 on Site A and click the Ping button. Are you able to get replies?
Note: As reference to the steps given to the above questions, kindly read page 388-389 of the SRX5308 reference manual here.
e. Is the modem connected to the SRX5308 (either Site A or Site B) a modem-only device or a modem-router combination?
f. What is the current firmware version of the SRX5308 on both sites? If ever it is not yet the latest version, I suggest you to update it to the latest version which is v4.3.5-3. Be sure to factory reset the SRX5308 right after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, observe if the same problem will occur. You can download firmware v4.3.5-3 here.
Let me share the following articles below that might help:
Configuring a Box to Box VPN on ProSAFE/ProSECURE routers using the VPN Wizard
Configure IPSec VPN Tunnels With the Wizard - read pages 3 to 5
DaneA
NETGEAR Community Team
- JamesN33Sep 04, 2018Aspirant
DaneA-
Thanks for your reply. Here is the info you requested..
The address ranges on both routers are different.
RouterA 192.168.70.0/24
RouterB 192.168.80.0/24
a. Yes
b. Yes
c. Yes
d. Yes
e. Each router is connected to ISP provided cable modem.
f. Firmware is current
I have also read the pages you suggested and the tunnel was created with the wizard as outlined in those pages.
Given the above facts should I be able to tracert successfully across the tunnel?
Thanks,
James
- DaneASep 05, 2018NETGEAR Employee Retired
Based from your answers, it seems that the VPN is all working fine.
When connected to the VPN tunnel, it is as if you are connected within the same LAN from Site A to Site B and vice versa. Hence, tracert through the VPN tunnel will not indicate the number of hops.
DaneA
NETGEAR Community Team- JamesN33Sep 05, 2018Aspirant
DaneA-
Thanks again for the reply. I am wondering if the problematic devices are being hindered but a mask issue? Both ends are /24 and I used /24 in the traffic selection in the IPsec setup. Is this correct?
Thanks,
James
