JamesN33
Aug 31, 2018Aspirant
SRX 5308 Site-to-Site VPN not fully working
Hi all,
New to the SRX5308 and Site-to-Site VPN. I have used the wizard and believe that I have a successful tunnel between two SRX5308. I have done nothing other than run the wizard. I can...
JamesN33
Sep 04, 2018Aspirant
DaneA-
Thanks for your reply. Here is the info you requested..
The address ranges on both routers are different.
RouterA 192.168.70.0/24
RouterB 192.168.80.0/24
a. Yes
b. Yes
c. Yes
d. Yes
e. Each router is connected to ISP provided cable modem.
f. Firmware is current
I have also read the pages you suggested and the tunnel was created with the wizard as outlined in those pages.
Given the above facts should I be able to tracert successfully across the tunnel?
Thanks,
James
DaneA
Sep 05, 2018NETGEAR Employee Retired
Based from your answers, it seems that the VPN is all working fine.
When connected to the VPN tunnel, it is as if you are connected within the same LAN from Site A to Site B and vice versa. Hence, tracert through the VPN tunnel will not indicate the number of hops.
DaneA
NETGEAR Community Team
- JamesN33Sep 05, 2018Aspirant
DaneA-
Thanks again for the reply. I am wondering if the problematic devices are being hindered but a mask issue? Both ends are /24 and I used /24 in the traffic selection in the IPsec setup. Is this correct?
Thanks,
James
- DaneASep 06, 2018NETGEAR Employee Retired
You may check the VPN Logs. Kindly refer to pages 339-443 on the SRX5308 user manual here about IPSec VPN Logs.
Yes, this is correct.
DaneA
NETGEAR Community Team- JamesN33Sep 06, 2018Aspirant
DaneA-
I have read all the recommended pages and still have a few questions..
1. At the risk of sounding stupid, how do I view the firewall logs? Under Monitoring/Firewall Logs & Email/View Log I can see a log but it does not appear to contain any firewall related entries.
2. I have noticed that when using the Monitoring/Diagnostics and using ping though tunnel that pings fail to some devices. From a command prompt however all devices across the tunnel respond to pings. What might explain this discrepancy?
Thanks again,
James
