JamesN33
Aug 31, 2018Aspirant
SRX 5308 Site-to-Site VPN not fully working
Hi all,
New to the SRX5308 and Site-to-Site VPN. I have used the wizard and believe that I have a successful tunnel between two SRX5308. I have done nothing other than run the wizard. I can...
DaneA
Sep 10, 2018NETGEAR Employee Retired
You may want to open a chat or online support ticket with the NETGEAR Support Team and attach the logs so that it will be forwarded to the engineering team for it to be analyzed.
Kindly try to use another WAN port of the SRX5308 on both Site A and Site B. Then, set up a VPN tunnel using the VPN Wizard as well. Check if the same problem will occur. You may want to perform a factory reset on both SRX5308 then reconfigure the setting from scratch and observe.
DaneA
NETGEAR Community Team
JamesN33
Sep 12, 2018Aspirant
DaneA-
Thanks for your help so far. One last question however. Is traffic on the site-to-site VPN runnning behind the firewall such that all ports both UDP and TCP be unrestricted by default? In other words VPN traffic should not affected by firewall rules?
Thanks,
James
