baloba2
Aug 19, 2016Aspirant
SRX5308 - DHCP client list not working after upgrade to 4.3.4-1
Hi.
After upgrading to 4.3.4-1 I cant see the dhcp client list in "lan groups"
It only shows the fixed bindings that I have made.
In release notes for that firmware:
"Fixed the is...
JohnRo
Aug 22, 2016NETGEAR Employee Retired
Hello baloba2,
Welcome to the community!
I've looked at the reported issues and known limitations for version 4.3.4-1 but did not see anything related. Did you try using other browsers? I cannot say that this is a bug as of now.
Thanks,
baloba2
Aug 22, 2016Aspirant
Hello and thanks.
I dont know what just happened.
I tested explorer 11 and edge,,,,,,on two pc.
It didnt work
Downloaded chrome and it worked.
Now it works whith explorer also......Hmmm.
Thanks for the help :)
Do you know why all my apple products shows up as unknown ??
When I check the logs it shows the name of the unit..
/Jerry
- JohnRoAug 22, 2016NETGEAR Employee Retired
Hi baloba2,
That was weird. It might be something with the browsers, could have been cache. I'm not sure about the apple products, if their hostname is defined they should show up fine. Did this issue occured after you have updated the firmware?
Thanks,
- baloba2Aug 23, 2016Aspirant
Hi.
The problem with unknown in the ip list has been there from the beginning maybe 2 years back.
Hmmm....now I cant see the list again....strange. Not even chrome.
It cant be a cache problem because I tested it on a ipad that never have been connected before.
So now i´ve tested eplorer, edge, chrome and safari and it doesn´t work.
- JohnRoAug 23, 2016NETGEAR Employee Retired
Hi baloba2,
This is getting weirder. Is it possible you can rollback the firmware to an older version just to confirm that version 4.3.4-1 is causing the issue? I may have to refer to you to Support and get a ticket filed, this needs to be looked at by engineering if it is a bug or not.
Thanks,
