baloba2
Aug 19, 2016Aspirant
SRX5308 - DHCP client list not working after upgrade to 4.3.4-1
Hi.
After upgrading to 4.3.4-1 I cant see the dhcp client list in "lan groups"
It only shows the fixed bindings that I have made.
In release notes for that firmware:
"Fixed the is...
baloba2
Aug 22, 2016Aspirant
Hello and thanks.
I dont know what just happened.
I tested explorer 11 and edge,,,,,,on two pc.
It didnt work
Downloaded chrome and it worked.
Now it works whith explorer also......Hmmm.
Thanks for the help :)
Do you know why all my apple products shows up as unknown ??
When I check the logs it shows the name of the unit..
/Jerry
JohnRo
Aug 22, 2016NETGEAR Employee Retired
Hi baloba2,
That was weird. It might be something with the browsers, could have been cache. I'm not sure about the apple products, if their hostname is defined they should show up fine. Did this issue occured after you have updated the firmware?
Thanks,
- baloba2Aug 23, 2016Aspirant
Hi.
The problem with unknown in the ip list has been there from the beginning maybe 2 years back.
Hmmm....now I cant see the list again....strange. Not even chrome.
It cant be a cache problem because I tested it on a ipad that never have been connected before.
So now i´ve tested eplorer, edge, chrome and safari and it doesn´t work.
- JohnRoAug 23, 2016NETGEAR Employee Retired
Hi baloba2,
This is getting weirder. Is it possible you can rollback the firmware to an older version just to confirm that version 4.3.4-1 is causing the issue? I may have to refer to you to Support and get a ticket filed, this needs to be looked at by engineering if it is a bug or not.
Thanks,
Hi.
I did a rollback and it worked fine.
I went back to 4.3.4-1 and did a factory reset and it seemes to be working.....
About the unknown problem.
In lan groups most of my devices shows up as unkown. The ones whith the correct names is the ones that is on a pc.
So, all my pcs shows the correct names but all apple products and sonos speakers etc. shows unkown....
An example.
In dhcp log:
DHCPOFFER on 10.0.0.220 to ac:7f:3e:e7:d7:** (airport-sovrum) via eth0.24
In lan groups:
unknown* 10.0.0.220 AC:7F:3E:E7:D7:** GROUP1
