InterContinenta
Feb 23, 2017Aspirant
SRX5308 and dvr's with multiple public ip
I have 13 public static ip's with 4 dvr's behind the firewall. I have added the appropriate ports in the services and can't get it to work. I see them in the land table. I have a SRX5308 v. 4.3.1-22...
- Mar 30, 2017
Thanks for the update. I'm glad to know that it was all figured out and all is working fine. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Mar 01, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
InterContinenta
Mar 30, 2017Aspirant
Sorry for the long delay in responding. it was actually comcast router. they didn't have all the static IP's loaded. Once they did that, they all worked fine.
- DaneAMar 30, 2017NETGEAR Employee Retired
Regards,DaneA
