Mats-S
Sep 03, 2016Tutor
SRX5308 and VOIP
Current firmware: 3.0.7-24 We have a problem with VoIP, telefony works fine but status LEDs on phones do not show status (busy/free). The latest firmware 4.3.4-1 states the following in the release...
- Sep 15, 2016
Hi, sorry for the delay.
today we disabled SIP ALG and rebooted the firewall. Now everything is workingn as expected.
Thanks,
/Mats
DaneA
Sep 05, 2016NETGEAR Employee Retired
Hi Mats-S,
Welcome to the community! :)
On the web-GUI of the SRX5308, go to Security > Firewall > Advanced. Is there a check mark on the box that says "Enable SIP ALG"?
DaneA
NETGEAR Community Team
Mats-S
Sep 05, 2016Tutor
Hi, Thanks for your reply.
Yes, SIP ALG is checked.
However, I'm unsure if we've rebooted the unit since checking it. Unsure if that matters though.
kind regards
/Mats
- DaneASep 05, 2016NETGEAR Employee Retired
Hi Mats-S,
Let us try this. Reboot the SRX5308 then check if same problem will occur.
If ever same problem will occur, uncheck the box that says "Enable SIP ALG" then click Apply. Observe if same problem will occur.
DaneA
- DaneASep 08, 2016NETGEAR Employee Retired
Hi Mats-S,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
