Mats-S
Sep 03, 2016Tutor
SRX5308 and VOIP
Current firmware: 3.0.7-24 We have a problem with VoIP, telefony works fine but status LEDs on phones do not show status (busy/free). The latest firmware 4.3.4-1 states the following in the release...
- Sep 15, 2016
Hi, sorry for the delay.
today we disabled SIP ALG and rebooted the firewall. Now everything is workingn as expected.
Thanks,
/Mats
Mats-S
Sep 05, 2016Tutor
Hi, Thanks for your reply.
Yes, SIP ALG is checked.
However, I'm unsure if we've rebooted the unit since checking it. Unsure if that matters though.
kind regards
/Mats
DaneA
Sep 05, 2016NETGEAR Employee Retired
Hi Mats-S,
Let us try this. Reboot the SRX5308 then check if same problem will occur.
If ever same problem will occur, uncheck the box that says "Enable SIP ALG" then click Apply. Observe if same problem will occur.
DaneA
NETGEAR Community Team
