PSmith
Mar 01, 2014Novice
SRX5308 BT Business ADSL
Anyone got this working? Vigor 120 + SRX5308. Using DHCP i can connect. Using BT Business Hub 3 i can connect and assign a fixed IP. Vigor 120 + SRX5308 with a static IP i cannot connect. O...
PSmith
Mar 02, 2014Novice
Thanks for the replies.
According to BT Business support, if i have multiple static ip addresses the router cannot have a static IP. It will always have a DHCP address and i have to assign the static IP to the device i want visible on the internet. This apparently doesn't cover a wan port (the representative didn't know what that was), i can however assign a static ip address to the router if i only have a single static ip.
Ho Hum.
Ho Hum.
