PSmith
Mar 01, 2014Novice
SRX5308 BT Business ADSL
Anyone got this working? Vigor 120 + SRX5308. Using DHCP i can connect. Using BT Business Hub 3 i can connect and assign a fixed IP. Vigor 120 + SRX5308 with a static IP i cannot connect. O...
jmizoguchi
Mar 02, 2014Virtuoso
Sounds like main IP are statically assign by dhcp which is no rare so that seems right
Rear you can use inbound rules and assign correct static ip on WAN section and forwarded to LAN device or use classical routing
