djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
adit wrote: Set it to only use WAN2 and test.
If no traffic passing, power cycle the Sierra and test again.
Ok just done this. Still not playing ball. Is there some further configuration that needs setting when I initially plug in another internet gateway besides the main WAN 1? Or should it simply be plug and play?
