djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
Mar 11, 2014Aspirant
Just done this again. Schecduled it for out of hours. It didn't roll over.
I unplugged WAN 1 expecting it to roll over to WAN 2. I did not. So I manually switched it so that WAN2 was the default connection. This just yielded an amber "Internet" LED. I couldn't access the Admin Panel at 192.168.1.9 and I also couldn't access the any external IP.
This is clearly more complex than a simple, set it as a roll over and job done. It's not working that way for me :(
