djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
Mar 12, 2014Aspirant
adit wrote: You need to make sure that the Sierra/ISP did not cache the MAC address of your test PC.
Even after a power cycle? How would I check this? I know it's not netgear hardware, but any keywords I'd be looking for would be great.
jmizoguchi wrote: Device on Sierra is router correct? Have you check on Sierra device make sure it is connected full time?
It's constantly connected to the HSPA network yep. It seems that accessing the 3g network may be a secondary issue at the minute. The biggest concern seems to be that I can't even access the admin panel on the Sierra router.
