djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
Mar 13, 2014Aspirant
jmizoguchi wrote: Do NOT use same LAN subnet on LAN and WAN.. . Change 4G to 192.168.2.9
Ok, I'll give this a go.
So will the clients still be able to connect even though it's on a different subnet?
For example, we have some static IP's on 192.168.1.x , would they still connect to a 192.168.2.x router?
I understand DHCP would connect to it fine :)
