djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
Mar 13, 2014Aspirant
adit wrote: I'm talking LAN and WAN.
So on the Sierra 4G router, should the ethernet cable (that's connected to WAN2 on the srx5308) be connected to the WAN or LAN port?
This is the current config:
LAN1 --> Switch 192.168.1.201
WAN1 --> Bonded Gateway 135.x.x.x external network
WAN2 --> Sierra 4G router 192.168.2.9 (changed FROM 192.168.1.9 under advisement from jmizoguchi)
I'll test to see if changing the subnet works (from 192.168.1.9 to 192.168.2.9) at close of business this evening at 6PM GMT.
