djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
djdanster
Mar 19, 2014Aspirant
jmizoguchi wrote: You are using double NAT since you have 192.x as WAN ip
Ok great, so would I change that in the srx5308's settings or in the Sierra 4G's settings?
