djdanster
Mar 10, 2014Aspirant
SRX5308 can't access WAN 2
So I've been tasked with setting up a rollover on WAN 2. In WAN 1, I've got 4xADSL modems going into a bonded gateway. This gateway connects to WAN 1. WAN 2 is plugged into a 4G Router. It's a S...
jmizoguchi
Mar 19, 2014Virtuoso
Sierra setting is that even option of device you are using
If you are using for just Internet you can use double NAT but not perfect scenario
