tbparker
Oct 29, 2017Aspirant
srx5308 firmware upgrade
I'm unable to upgrade my firmware to 4.3.5.3. It keeps taking me back to the login screen.
DaneA
Nov 05, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to perform the steps I suggested? If yes, what is the result?
DaneA
NETGEAR Community Team
- tbparkerNov 05, 2017Aspirant
The factory reset did the trick.. Thank you
- DaneANov 05, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that you were able to upgrade the firmware after doing a factory reset. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
