p912s
Jan 22, 2021Aspirant
SRX5308 GUI not visible from browser and all ports show closed on nmap scan
Hello all! We have 5 locations that are connected via VPN using SRX5308 routers. They've been in place going back several years. Originally locations were connected using FVG318 routers and those...
- Jan 28, 2021
Is there a was to do a backup to a local pc same as you do thru the GUI?
I don't think that there's another way to backup the config that is the same or similar as through the web-GUI. With this, you will need to reconfigure the SRX5308 from scratch after doing a factory reset.
DaneA
NETGEAR Community Team
p912s
Jan 27, 2021Aspirant
I see thru the CLI that I can do a backup, but it looks like it will only go to an FTP site. Is there a was to do a backup to a local pc same as you do thru the GUI?
Thanks
DaneA
Jan 28, 2021NETGEAR Employee Retired
DaneA
