bhoth's avatar
bhoth
SRX5308 Ipv6 problems with Comcast
Hi All, after installing the most recent firmware I decided to finally turn on IPv6. My ISP is Comcast and they tell me they are fully compatible and ready to go with IPv6.
After selecting IPv4 / IPv6 mode, the router reboots and now I am picking up a fake address not a real one from comcast. The ip starts with fe80 and I have read that fc through fe addresses are not real routable addresses.
Has anyone else successfully configured an SRX5308 with Comcast?
    • bhoth's avatar
      bhoth
      Hi I found the document "How to Configure Dynamic IPv6 Connection on a PROSAFE Firewall.pdf" from another thread and it got me going.
      Thank you,
      • JohnRo's avatar
        JohnRo
        NETGEAR Employee Retired
        Hi bhoth,
        We are glad to know that one of our KB's helped you out. If this fixes your issue we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
        Thanks,
ProSupport for Business
