herrmann_daniel
Aug 20, 2015Aspirant
SRX5308 Load balancing with protocol binding problem
I have 3 Internet connections in load balancing mode. All outgoing traffic to a specific IP adress (mail hub) must go through specific WAN port where I have a dedicated IP address. If any other WAN p...
herrmann_daniel
Aug 29, 2015Aspirant
Hi DaneA, a. Firmware is 4.3.3-5 b. Load balancing method is Weighted LB Block UDP flood is not checked. What is the behavior I should expect if protocol binding is configured and the internet connection on the WAN port that is programmed is down? Should packets go through any other WAN port available? Or should they just not go through? Regards, Daniel
DaneA
Aug 30, 2015NETGEAR Employee Retired
Hi herrmann_daniel,
Thanks for your response.
With regard to your concern, since you have 3 WAN connections, let say for example WAN1 port goes down, all of the services that are binded to it will be all down and it will not switch to any other WAN ports.
DaneA
Netgear Community Team
- herrmann_danielAug 30, 2015AspirantSo there is in fact a problem. I created a rule in Protocol Binding that says that any service from a single lan address to a single Internet address should go through a specific WAN port. I use this to send emails from our internal mail server to an Internet mail hub. This mail hub rejects all messages that do not come from a specific IP address. Checking the log of the mail hub I can see that it receives sometimes mails from one of the other WAN connections. I don't know if this happens due to connection failures on the specific WAN connection or if the Protocol Binding is not working correctly. Is there any way I can troubleshoot this further?
- DaneAAug 31, 2015NETGEAR Employee Retired
Hi herrmann_daniel,
Based from you have previously stated, do you have any inbound or outbound firewall rules configured on your SRX5308?
DaneA
- herrmann_danielAug 31, 2015AspirantHi, there are no outbound rules but some inbound: 1 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN1 NONE Never 2 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN2 NONE Never 3 SMTP587 ALLOW always 192.168.70.1 Any NONE WAN3 NONE Never 4 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN1 NONE Never 5 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN2 NONE Never 6 VNC5910 ALLOW always 192.168.70.10 Any NONE WAN3 NONE Never 7 HTTPS ALLOW always 192.168.70.1 Any NONE WAN1 NONE Never 8 HTTPS ALLOW always 192.168.70.1 Any NONE WAN2 NONE Never 9 HTTPS ALLOW always 192.168.70.1 Any NONE WAN3 NONE Never Below you can see part of the log from the mail hub. WAN3 of the SRX5308 has the IP 177.249.113.112 which is allowed on the mail hub. WAN1 has the IP 187.209.254.49 and is not allowed on the mail hub. Protocol binding should ensure that mail only goes through WAN3. 2015-08-31 11:24:32 [email protected] [email protected] PEDIDO 3000_651 TA... Sent 177.249.113.112 2015-08-31 11:29:01 [email protected] [email protected] TRANSMITTAL FIRMAD... Sent 177.249.113.112 2015-08-31 11:30:04 [email protected] [email protected] RV: COTIZACION DE ... Sent 177.249.113.112 2015-08-31 11:34:57 [email protected] [email protected] RV: Pago proyecto Sent 177.249.113.112 2015-08-31 11:39:30 [email protected] [email protected] Rejected 187.209.254.49 2015-08-31 11:39:30 [email protected] [email protected] Rejected 187.209.254.49 2015-08-31 11:40:54 [email protected] [email protected] Rejected 187.209.254.49 2015-08-31 11:47:09 [email protected] [email protected] RV: RELACION DE ... Sent 177.249.113.112 2015-08-31 11:48:38 [email protected] [email protected] Estudio de comunic... Sent 177.249.113.112 I allready tried with some variaton on the protocol binding rule like: - any service from local IP 192.168.70.1 that goes to 216.55.99.127 uses WAN3 - SMTP 587 from local IP 192.168.70.1 that goes to 216.55.99.127 uses WAN3 - any service from local IP 192.168.70.1 that goes to any internet address uses WAN3 But there are always some mail that go through WAN1 and are rejected therfore by the mail hub. Regards, Daniel
