Retired_Member
Jul 21, 2017SRX5308 Protocol Binding Services PORT 443 LB
Hi, with 2 ISP using static IP addresses (Load Balancing) I use use Protocol Binding to always have the same IP address for specific services. It's already working, see overview bellow: Service ...
- Jul 22, 2017
Hi fnb,
Welcome to the community!
As per checking in here that you do have HTTPS was set to WAN2. The SPECIAL that you created will have a conflict on the HTTPS port which is already set to WAN2. It does not recognizes the port 443 on WAN 1. You may try to use a custom port and translate in order for this to work as you cannot use the port 443 anymore.
JohnC_V
Jul 22, 2017NETGEAR Employee Retired
Hi fnb,
