Anonymous
Jul 21, 2017SRX5308 Protocol Binding Services PORT 443 LB
Hi, with 2 ISP using static IP addresses (Load Balancing) I use use Protocol Binding to always have the same IP address for specific services. It's already working, see overview bellow: Service ...
- Jul 22, 2017
Hi fnb,
Welcome to the community!
As per checking in here that you do have HTTPS was set to WAN2. The SPECIAL that you created will have a conflict on the HTTPS port which is already set to WAN2. It does not recognizes the port 443 on WAN 1. You may try to use a custom port and translate in order for this to work as you cannot use the port 443 anymore.
JohnC_V
Jul 25, 2017NETGEAR Employee Retired
Retired_Member,
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply is the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- AnonymousJul 25, 2017
Hi JohnCarloV,
I guessed that would the issue (having the port 443 twice).
Thanks for your reply.
