TooMuchTrouble_
Oct 12, 2011Aspirant
SRX5308 Settings spontaneously disappear
I set up a brand new SRX5308 yesterday as follows: factory reset (using button) update fimware factory reset (using button) configure Today I swapped it in to replace the existing router and, ...
jmizoguchi
Oct 12, 2011Virtuoso
assume you are using IE or firefox browser?
when you say configure means manually correct?
another resetting after this issues does it fixes?
