TooMuchTrouble_
Oct 12, 2011Aspirant
SRX5308 Settings spontaneously disappear
I set up a brand new SRX5308 yesterday as follows: factory reset (using button) update fimware factory reset (using button) configure Today I swapped it in to replace the existing router and, ...
jmizoguchi
Oct 13, 2011Virtuoso
use firefox instead if you are Mac user.
new firmware should not cause Safari to do erratic behavior but I would use firefox
