sethrb
Oct 15, 2018Aspirant
SRX5308 Subnet Bridging
Hi there!
We have two different locations that are connected by a direct gigabit connection provided by ISP.
Location 1 subnet: 192.168.1.x
Location 2 subnet: 192.168.2.x
Currently t...
sethrb
Oct 24, 2018Aspirant
I did get this working last night using the inter-vlan routing method, so thank you for that! I had tried similar steps before but I must have gotten something wrong in the process.
The only problem now is that everything is communicating across the two locations fine EXCEPT our ESI phone systems, which are linked to allow us to forward calls between the two locations. I'm not an expert in this area, but I believe the systems communicate with each other on UDP port 59. Is there any reason why the inter-vlan routing method would not allow that traffic to pass, and if so is there a way that I can allow it?
Thanks!
sethrb
Oct 26, 2018Aspirant
Just wanted to give an update that we figured this out in case anyone else in the world ever has this unique issue. There was an IP PBX gateway setting that we needed to change on our phone system to point to the IP of the SRX router now acting as the bridge between the networks. After that change all is working smoothly!
Thank you for your help!
